show mpls rsvp-te lsp [egress | transit]
show mpls rsvp-te lsp [egress | transit] {fast-reroute} {{lsp_name} {[destination | origin] ipaddress} {detail} | summary}
Description
Displays complete or filtered information for one or all egress or transit RSVP-TE LSPs.
Syntax Description
egress Limits the display to only the LSPs that terminate at this switch.
transit Limits the display to only the LSPs that transit this switch.
fast-reroute Limits the display to only those LSPs with fast reroute protection.
lsp_name When either the transit or the egress option is specified, this variable specifies a name for a single LSP for which information is displayed.
destination Displays only those LSPs that terminate at the specified IP address.
origin Displays only those LSPs that originate at the specified IP address.
ipaddress Specifies an IP address for an LSP origin or destination.
detail Displays the LSP information in verbose format.
summary Displays only the LSP summary statistics section of the normal display.
Default
N/A.
Usage Guidelines
You can limit the display to ingress LSPs with the following command:
show mpls rsvp-te lsp [ingress {fast-reroute} | ingress_lsp_name | ingressingress_lsp_name | ingress [destination | origin]ipaddress] {[all-paths | detail] | summary | down-paths {detail}}
You can display information for all LSPs with the following command:
show mpls rsvp-te lsp {{[destination | origin] ipaddress} {fast-reroute} {detail} | summary}
When label recording is enabled for an LSP, labels are displayed only for the ingress node (the egress label from the previous node always matches the ingress node label).
The following command example displays RSVP-TE LSPs that terminate at this switch and at IP address 11.100.100.30:
# show mpls rsvp-te lsp egress destination 11.100.100.30
Egress LSP Name  Source IP       Destination     Prev Hop I/F     UpTm
tom3             11.100.100.55   11.100.100.30   m5vlan1            5m
frrlsp1tom3      11.100.100.50   11.100.100.30   m2vlan1            5m
Summary of Egress RSVP-TE LSPs to destination 11.100.100.30
Egress LSPs                              : 3
Egress Protected LSPs                    : 0
This command was first available in ExtremeXOS 11.6.
This command and its output were modified, and the summary option was added in ExtremeXOS 12.0.
The fast-reroute feature was first available in ExtremeXOS 12.1.
This command and its output were modified in ExtremeXOS 12.2.2.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
